uriel70271 Posted January 18, 2019 Report Share Posted January 18, 2019 Hello everyone, I have a question with my journey 2015, the problem is ,when I put the reverse one feels a knock , I hope to explain well, just do not do all the time only sometimes, just happens to put reverse, I hope someone can help and thank you very much for your time Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 18, 2019 Report Share Posted January 18, 2019 depends how long have you have had it , most journeys have some knocks or like a surgeĀ feel when going into drive or rev at times mine use to, hasn't done it in a long time, they can do updates on the software, sometimes that helps and most of the time it doesn't, also depends on your mileage might also could be trans mount since its only does it in rev, hard to tell from here, but on the avg i dont think you have a problem other than the slight noise. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 18, 2019 Report Share Posted January 18, 2019 also go to the area marked forums and scroll down to the engine and drive lines you will find out there is so much info on your problem there jkeaton 1 Quote Link to comment Share on other sites More sharing options...
