ramrezz425 Posted February 17, 2019 Report Share Posted February 17, 2019 (edited) Has anybody used something else to attach the grill besides those five little pushpins (item 3), they look like they’re easy to break, is there any special tool or technique to remove them without damaging them? trying to find a video here on this forum could not find it. Edited February 17, 2019 by ramrezz425 Add pic Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 17, 2019 Report Share Posted February 17, 2019 I use a tool like this. https://www.harborfreight.com/5-piece-upholstery-and-trim-tool-set-99739.html OhareFred 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 17, 2019 Report Share Posted February 17, 2019 I have an 09, which I got in 08, and none have broken.... 2late4u and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted February 19, 2019 Report Share Posted February 19, 2019 (edited) In most applications the pin is two pieces. The center of the pin should lift out with the proper tool. Once the center piece is removed, the outer piece will just lift out. They are easy to break and it is always good to have a few extras on hand. Edited February 19, 2019 by Summer Solstice Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 19, 2019 Report Share Posted February 19, 2019 59 minutes ago, Summer Solstice said: In most applications the pin is two pieces. The center of the pin should lift out with the proper tool. Once the center piece is removed, the outer piece will just lift out. They are easy to break and it is always good to have a few extras on hand. i bought some off amazon mostly the bigger ones that go around the wheel wells size i do believe there is a mix selection of varied sizes for sale OhareFred and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
