Losing ATF all over undercarriage from where?
ejleo
2010 Journey 3.5, Fwd with 62TE Trans leaking all over the undercarriage  but I can't find the source to save my life.   Its primarily leaking down differential housing and getting all over cross member/undercarriage so badly I have to put in a quart about 30 miles.
I ruled out axle seals and top solenoid gasket after observing axles spinning under pressure while on stands.  Nothing from cooler coil connections (at top side at least)   See pics.
What else would cause that much of a huge leak?      Is it possible the differential bolts came loose?     I'm not sure if the pump seal could leak like that.  Anyone experience this?
  • 5 months later...
