blissman20 Posted March 15, 2019 Report Share Posted March 15, 2019 Hey everyone, I have a 09 journey awd v6. It is a 7 seater with sunroof. I’m wondering has anyone put in a roof mount DVD player. Is there enough room to mount one? I’d like to snag one out of a dodge caravan. Any ideas or help is appreciated. Main reason I’d like a roof mount is because I have 4 Kids (8,5,3,4 months and we aren’t done according to my old lady). If I can’t do roof mount I’ll do removable cheap headrest ones Quote Link to comment Share on other sites More sharing options...
OhareFred Posted March 16, 2019 Report Share Posted March 16, 2019 There was much discussion on this in the past. Try a forum search but.... To install a roof mount you need to remove the headliner, then install support brackets, replace the rear heat/AC controls(I think) with a different style. then run wires/cables from the radio to the unit. As I recall the consensus was go with the headrest mount. Good luck.... jkeaton 1 Quote Link to comment Share on other sites More sharing options...
blissman20 Posted March 17, 2019 Author Report Share Posted March 17, 2019 20 hours ago, OhareFred said: There was much discussion on this in the past. Try a forum search but.... To install a roof mount you need to remove the headliner, then install support brackets, replace the rear heat/AC controls(I think) with a different style. then run wires/cables from the radio to the unit. As I recall the consensus was go with the headrest mount. Good luck.... Thanks! I kept searching and searching on here and the results came up nil, or it changed my keywords. Joys of searching from a mobile device. You gave me all the information I needed. Thanks again! Headrest ones are the way to go! Cheaper and easier I imagine too! Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 17, 2019 Report Share Posted March 17, 2019 (edited) Be aware the Journey has “active” headrests. A part of the SRS. Check your manual and verify if hanging anything on them impacts their operation. Edited March 17, 2019 by jkeaton OhareFred 1 Quote Link to comment Share on other sites More sharing options...
