No power
  On 3/16/2019 at 2:18 PM, OhareFred said:
More info would be helpful.  Engine, exactly what do you mean by no power? Does the dash light up? Headlights work? Etc.
From the info you gave us, I would say check your battery cables.  Might have come lose...
Expand
No power at all anywhere even when I tried boosting it
Check fuses and fusible links (if there are any). Sounds like you fried something, or something is not connected. Who replaced the battery and alternator? Why were they replaced? The more info you provide, the better we can try to assist you. Otherwise, you need to get it looked at by a shop if you don’t know how to check basic things, trace wiring, etc.
Edited by jkeaton
  • 8 months later...
  On 11/18/2019 at 6:24 PM, Minikooperis said:
Hi,are you fix that problem ? Because i have this too...?
Expand
3 post wonder, asking for help but then never reports back what he found out was the problem .good luck on your  problem as well please re-post when you find out the problem for others
