Strange Drivers Door Behavior
jgfan1972
I have a strange  issue with my drivers door.  The door only thinks that it is open for a small range of the door.  When the door is all the way open its as if the door is shut.  The key in the ignition dinger only dings for a second when you open or close the door.  Hopefully this explains the issue.  Its driving me nuts.
Is it causing other issues?  If all that’s going on is a short ding, I’d leave it alone myself. However, if your having issues with window operation, mirrors, or door locks check the wire loom going into the door. As mentioned, 09’s had a recall for the wiring that goes into the door.  Not sure if 10’s are in that or not.
