nino Posted May 13, 2019 Report Share Posted May 13, 2019 Here’s a great video on how to change out the spark plugs on a 3.6L 2012 DJ. Was looking around the forums and couldn’t really find a proper video. hope this helps. Quote Link to comment Share on other sites More sharing options...
2late4u Posted May 13, 2019 Report Share Posted May 13, 2019 (edited) 18 minutes ago, nino said: Here’s a great video on how to change out the spark plugs on a 3.6L 2012 DJ. Was looking around the forums and couldn’t really find a proper video. hope this helps. make sure you use a magnetic spark plug socket..... as using a reg socket or one with a rubber boot may let the plug slip out and the plugs are about 4-6 inches down inside a small area.this is with the 3.6 engine and the 2.4 engine as well..... i would also cover up the 3 open areas in the middle of the engine with a rag just in case something doesn't slip or fall into the the holes not sure what they are but to be safe precaution and DONT forget the insulation pad like he did... i am sure its there for a reason.. BUT a good video Edited May 13, 2019 by 2late4u bobert and nino 2 Quote Link to comment Share on other sites More sharing options...
