Steering Wheel noise (inside cabin)
Hi....Not sure where to put this post, so I'll leave it here.
I have weird scraping type noise only heard inside the cabin of the car and when turning the steering wheel left and right.  The best way for me to describe it would be to say that it sounds like the components behind the steering wheel is rusted and needs lubrication.  I will try to get a sound clip of it.  I thought maybe the clock spring, but all the steering buttons and horn works.  The noise is definitely coming from behind the steering wheel/column.
Any ideas?
The clock spring is part of the steering angle sensor.  I just replaced mine.  Cost about 600 bucks Canadian at the dealer.  3 hours to put in.  Not cheap.  The sensor was screwed, but the buttons and horn still worked.
mechanical-idiot
Edited by mechanical-idiot
I purchased the part at the dealer.  I had a mechanic install it at a garage.  It was a 3 hour job.  There are lots of online videos about how to install one.  Basically it is the same procedure for all vehicles.
I got a 2 year warranty on the part.  It is not worth buying a used one at a salvage yard.  I could have saved some $, but would have spent it again on labour if the second hand one screwed up.
mechanical-idiot
  • Official Dodge Support
Any ideas?
Are you thinking you'd like to get this inspected by your Dodge dealer? Send me a direct message if you need any assistance with that process.
Jasmine
Dodge Social Care Specialist
  • 2 months later...
