Justinsomera Posted June 6, 2019 Report Share Posted June 6, 2019 I have a 2012 Dodge Journey. Alarm won’t activate.fob can’t be detected. Can’t lock or unlock car with fob or door switches! And have to jump start car every other day because car battery dies. Please help! Quote Link to comment Share on other sites More sharing options...
probak118 Posted June 6, 2019 Report Share Posted June 6, 2019 After you do jump start it, go and get the charging system and battery diagnosed. First see if there is a problem with the alternator or battery themselves.I just changed my original 2012 battery this past Spring.Then, move on from there. mechanical-idiot, OhareFred, Justinsomera and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
larryl Posted June 6, 2019 Report Share Posted June 6, 2019 Original battery??? if it is change it out and proceed from there jkeaton and Justinsomera 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 6, 2019 Report Share Posted June 6, 2019 Definitely get the battery and charging system tested. Welcome to the forum. Justinsomera 1 Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted June 6, 2019 Report Share Posted June 6, 2019 as above mechanical-idiot Justinsomera 1 Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted June 6, 2019 Report Share Posted June 6, 2019 Your HFM module (blue tooth) could be draining it. Common problem. Pull fuse 131 under the dash on the passenger side. Charge it. If it does not go dead, then that is your problem. mechanical-idiot larryl and Justinsomera 2 Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted June 7, 2019 Report Share Posted June 7, 2019 Replacing the battery might fix all of these issues. When the battery gets faulty, all the gremlins start showing up. When mine was showing similar symptoms, all I could think was about how much replacing the Bluetooth module would be. There was also a rumor that the battery temperature sensor (What?) was faulty. I took it in to swap the battery for a new one- all my issues went away. My gremlins were that the volume knob wasn't working well (What's in have to do with the battery dying?!?!), and the radio kept resetting in the week prior to the battery failing on me. After that, the car wouldn't recognize the key fob for key-less entry ("service keyless entry system" warning), and finally, it wouldn't start, and even after jumping, couldn't even hold idle without stalling. After the battery was swapped (no issues with the alternator, thankfully), I've not had any issues with the radio stack. Goodyear did mine for $145 Justinsomera 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted June 7, 2019 Report Share Posted June 7, 2019 One post wonder..... Quote Link to comment Share on other sites More sharing options...
Justinsomera Posted June 8, 2019 Author Report Share Posted June 8, 2019 (edited) 8 hours ago, NavalLacrosse said: That’s really weird! Gonna give a try! Thanks! Edited June 8, 2019 by Justinsomera mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
