Robert Holman Posted June 11, 2019 Report Share Posted June 11, 2019 I had both struts assemblies replaced along with two new tires on the front end as well as an alignment. I am having a vibration and it still pulls to the left. Also, when driving, if I happen to cross over a rough patch in the road on the right side of my vehicle it seems to want to perform independently and steer away. It gives the impression that it is going to just fall off. Any suggestions as to what the issue is? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 11, 2019 Report Share Posted June 11, 2019 probally a bad tire,quick way to check that is rotate the front to the rear if the problem is gone then its the new tire, if i remember right if its pulling to the left it is prob the right side tire that might have a broken belt, could also be a bad rim.good luck jkeaton and mechanical-idiot 2 Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted June 11, 2019 Report Share Posted June 11, 2019 If they vibrate on the back, then it is a broken belt or an imbalanced rim/tire. mechanical-idiot jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted June 12, 2019 Report Share Posted June 12, 2019 Was the vibration there before you had the work done? What was mentioned above is good advice. I had two new tires and some front end work done on a different vehicle. Both the front end work and one of the new tires went bad. The tire had a bubble that caused vibration and was replaced. Once the vehicle was returned from the shop a second time, the vehicle had enormous torque steer that they told me was normal. It had 250.000 miles on it and had never done it before. Short story is I found that the 35lb max tire was inflated to 60lbs and I drove it like that for 2 months never thinking to check for that. Take it back to the shop and have them check their work. Check the tire pressures your self. mechanical-idiot, jkeaton and 2late4u 3 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted June 12, 2019 Official Dodge Support Report Share Posted June 12, 2019 23 hours ago, Robert Holman said: I had both struts assemblies replaced along with two new tires on the front end as well as an alignment. I am having a vibration and it still pulls to the left. Also, when driving, if I happen to cross over a rough patch in the road on the right side of my vehicle it seems to want to perform independently and steer away. It gives the impression that it is going to just fall off. Any suggestions as to what the issue is? Hi Robert Holman, We understand why this may be concerning. We suggest having your dealer inspect this concern if you have not done so already. We are also available via private message if you would like any additional assistance during that process. Lydia Dodge Social Care Specialist jkeaton 1 Quote Link to comment Share on other sites More sharing options...
