MikeKennedy39 Posted June 11, 2019 Report Share Posted June 11, 2019 My tailgate doesn't get a signal from the lock button or the remote. I took off the tailgate cover and I know how to use the screwdriver to unlock the gate from the inside or when the gate is open. But, before I start replacing parts, I want to check the location of the fuse. I think it is under the glove box, but I want to know WHICH fuse runs to the tailgate. I see driver door and passenger door, but no TAILGATE. Any help would be appreciated. Thank you, Mike Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted June 12, 2019 Report Share Posted June 12, 2019 There is no separate fuse for the lift gate listed in the owner's manual. There is, however, a known and common issue with the wiring harness as it passes from the body to the lift gate. Perhaps there is a single wire issue there effecting your locks on the lift gate. mechanical-idiot and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 12, 2019 Report Share Posted June 12, 2019 2 hours ago, Summer Solstice said: There is no separate fuse for the lift gate listed in the owner's manual. There is, however, a known and common issue with the wiring harness as it passes from the body to the lift gate. Perhaps there is a single wire issue there effecting your locks on the lift gate. This ^^ Check the wires inside the loom going from the body to the tailgate. mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
