nino Posted June 12, 2019 Report Share Posted June 12, 2019 Hello everyone, just looking for a little advice. I have a 2011 DJ crew with about 150000km on. hooked up the OBD scanner and I’m getting the P0123 (TPS/APP circuit high) and PO222 (throttle position sensor 2 high) codes. Anyone know what I can do to resolve the issue or would it just be easier to get it replaced? Also, side note... would this have anything to do with my battery being drained? Battery was only 2 months old and drained down to nothing. Luckily warranty kicked in for it Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 12, 2019 Report Share Posted June 12, 2019 Are you experiencing driveability issues? If you just had the battery replaced, clear the codes and see if they come back. mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
nino Posted June 12, 2019 Author Report Share Posted June 12, 2019 (edited) Hey @jkeaton, I am having issues where there’s a little bit of rough idling when at a red light and a little hesitation when shifting through gears. Slight hesitation. Already tried clearing the codes and codes came back right away. Edited June 12, 2019 by nino Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 12, 2019 Report Share Posted June 12, 2019 what engine do you have, and how many miles, could be a plug problem mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
nino Posted June 12, 2019 Author Report Share Posted June 12, 2019 3.6L. Has about 150000km so that’s about 93000 miles Quote Link to comment Share on other sites More sharing options...
larryl Posted June 12, 2019 Report Share Posted June 12, 2019 If you are going to change the TPS I would do the plugs also....and the tranny fluid mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
nino Posted June 12, 2019 Author Report Share Posted June 12, 2019 @larryl plugs and tranny fluid have already been done within the last 2 months as well. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 13, 2019 Report Share Posted June 13, 2019 Maybe try cleaning the throttle body. Or run a can of lucas fuel injector cleaner. mechanical-idiot 1 Quote Link to comment Share on other sites More sharing options...
