Sunroof Drain Exits
Hello! Hoping someone may be able to help me. I’ve noticed a pretty heavy drip from my right rear corner area of sunroof (coming in from above the track) I recently learned there are drains in the sunroof area one in each corner. Does anyone know if each drain exits the vehicle on the same side. For example front drivers side drain will exit behind the front drivers wheel. So are there 4 exit areas? Just trying to conduct a test to see if they are blocked or if the water is draining as it should.
Thanks for any tips or advice!
  • Official Dodge Support
Hello mwsdhd,
We are sorry to hear of this concern with your sunroof. Have you had a chance to reach out to your dealership for additional insight? Please send our team a private message if you decide to move forward with a dealership appointment.
Jenn
Dodge Social Care Specialist
Thanks I have already made an apt with the dealership as I am quite confident that it’s a leak with the seal but all I wanted to know from this is how many drain exits there are on the vehicle and the location for them.
I unfortunately have found this vehicle to be extremely unreliable with one issue right to the next. It’s been less than 1 week since I’ve been in the shop with it. Disappointing to say the least.
mwsdhd,
I tested my sunroof drains (2) after noticing a couple small water marks on each of the "A" post where it meets the roof liner. My two drains exit on each side alongside the inside of the front tires, on the same side as the drain holes.
