rsw0913 Posted June 17, 2019 Report Share Posted June 17, 2019 about a month ago the instruments started going haywire. traction control, check engine light, low tire....essentially all of them start going off including the windshield wipers. i found some info that indicated the cluster was bad. Does this sound like the problem? I can disconnect the battery but the problem usually returns within a few miles now. I found a website that has used instrument clusters, quite a bit cheaper than a new replacement. they program your mileage and indicate that you just plug it in. Thoughts?? Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 17, 2019 Report Share Posted June 17, 2019 first have your battery checked at your local part store have them do a load check, low batteries can cause crazy things to happen to the electronics, now since you said this has been going on for a month it could be your cluster going bad or maybe some loose wires behind it shorting out, hard to say for sure. good luck but get that battery checked first since its a free check larryl and mechanical-idiot 2 Quote Link to comment Share on other sites More sharing options...
rsw0913 Posted June 17, 2019 Author Report Share Posted June 17, 2019 battery isn't that old but i had already planned on getting that checked prior to changing the cluster. i saw some other posts that indicated it could be the battery. thanks.... 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted June 17, 2019 Report Share Posted June 17, 2019 39 minutes ago, rsw0913 said: battery isn't that old but i had already planned on getting that checked prior to changing the cluster. i saw some other posts that indicated it could be the battery. thanks.... when you said the wipers acting up, that should not be intertwined with the cluster acting up?good luck and keep us informed what you find out for others to see Quote Link to comment Share on other sites More sharing options...
rsw0913 Posted June 17, 2019 Author Report Share Posted June 17, 2019 yes...on occasion the wipers will just go on for no reason at all. the chime starts dinging and the instrument cluster goes haywire. speedometer, tach all gauges start going out of whack. my other thought is possibly the body control module. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted June 17, 2019 Report Share Posted June 17, 2019 After the battery check, get your codes checked. That should tell you if the BCM is bad. Dealer for that one. Best of luck. mechanical-idiot Quote Link to comment Share on other sites More sharing options...
rsw0913 Posted June 17, 2019 Author Report Share Posted June 17, 2019 battery and alternator are good...Next to check on the BCM. Thanks mechanical-idiot. If it doesn't throw a BCM code then can i assume that the instrumental cluster is bad? Quote Link to comment Share on other sites More sharing options...
mechanical-idiot Posted June 18, 2019 Report Share Posted June 18, 2019 When the dealer mechanic checks the codes, he or she should be able to tell you if the cluster is the next possible suspect (providing that the BCM is not the culprit). You can get them to diagnose the problem, you don't have to get them to fix it. You just pay for the diagnosis. Most of them are good to help and give some advice. They know the vehicle and they have seen most of the problems before. The codes will tell them and you what is wrong. Get a printout of the codes. Best of luck mechanical-idiot 2late4u 1 Quote Link to comment Share on other sites More sharing options...
rsw0913 Posted June 18, 2019 Author Report Share Posted June 18, 2019 thanks for the help mechical-idiot. you are confirming what i have been told by another forum. take it to the dealer and have them check the code. i'll update when i get that done. i have friend that has a code machine but from what i am hearing this is a problem that may require the dealer's code reader. i'll try the friend first since it's free. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted June 18, 2019 Official Dodge Support Report Share Posted June 18, 2019 1 hour ago, rsw0913 said: thanks for the help mechical-idiot. you are confirming what i have been told by another forum. take it to the dealer and have them check the code. i'll update when i get that done. i have friend that has a code machine but from what i am hearing this is a problem that may require the dealer's code reader. i'll try the friend first since it's free. Hi rsw0913, We understand your concern. Once you are able to visit your dealer for an inspection, you're welcome to send us a private message for additional assistance. Lydia Dodge Social Care Specialist Quote Link to comment Share on other sites More sharing options...
Nazkar86 Posted May 9, 2021 Report Share Posted May 9, 2021 Did you ever get thia figuree out? My journey has been doing the same thing. It started intermittently. Now its an all day thing. I was told TIPM...replaced that TWICE still the same issue Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted May 9, 2021 Report Share Posted May 9, 2021 4 hours ago, Nazkar86 said: Did you ever get thia figuree out? My journey has been doing the same thing. It started intermittently. Now its an all day thing. I was told TIPM...replaced that TWICE still the same issue Not sure if the "fix" would be the same for your DJ as they underwent a big redesign in 2011. I would start out with checking/cleaning the grounds on the strut towers. also a good independent shop should have a higher level than basic OBD11 code scanner that can read all systems(BCM/ABS/SRS) to help narrow down area where the problem is. A dealer level scanner can go even further to test each system and component, but it will cost you. Also if you have had any "add on" installed over the years, I would recheck any spliced in wiring for them. Quote Link to comment Share on other sites More sharing options...
