Bill Adams Posted July 12, 2019 Report Share Posted July 12, 2019 2012 Dodge Journey SXT 3.6 engine. symptoms when breaking it seems like the ABS is activating even under medium braking. Pedal jerks and vibrates. I took it to a shop that SAID they do ABS. they read codes then told me “You have to take it to a shop that does ABS.” ?? C0021-02 Booster C0020-16 ABS pump C0034-62 Right wheel speed (which I just replaced, ) P258b vacuum pump At least they only charged me $20. I recently replaced the rear calipers, screwed up and let the whole system drain of fluid. I’m thinking vacuum pump, because it seems like that would cause the other two codes. Any suggestions? Thanks. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 12, 2019 Report Share Posted July 12, 2019 Did you get it bled correctly after allowing the entire system to drain? Quote Link to comment Share on other sites More sharing options...
