Pedal vibrates when braking.
2012 Dodge Journey SXT
3.6 engine.
symptoms
when breaking it seems like the ABS is activating even under medium braking. Pedal jerks and vibrates.
I took it to a shop that SAID they do ABS.
they read codes then told me “You have to take it to a shop that does ABS.”  ??
C0021-02 Booster
C0020-16 ABS pump
C0034-62 Right wheel speed (which I just replaced, )
P258b vacuum pump
At least they only charged me $20.
I recently replaced the rear calipers, screwed up and let the whole system drain of fluid.
I’m thinking vacuum pump, because it seems like that would cause the other two codes.
Any suggestions?
Thanks.
