Installing New Amp & Subwoofer
  • 1 year later...
I am not sure if there are any unused inlets available but if you were to drill, the hole should be drilled in the firewall and come out under the dash but above the pedals.  Obviously not close to anything mechanical (moving parts) as well as any current wires.  You will then need a grommet installed in the drilled opening to protect the new power wire.  I did a quick Google search for examples. Hope this helps.
