No RCA on 2017 Journey Factory Radio
  On 7/19/2019 at 2:56 AM, Pity Pat.Patton said:
So im hitting multiple road blocks when installing my new sound system amp. The radio has no place for the RCA cables. Also do i need a anything to connect the remote wire to the factory setup? Pictures are helpful
Expand
This is what I did, which solves both of your problems:
Audiocontrol LC2i  They are about $70 on Amazon or BestBuy carries them as well.
Edited by Kwyjibo
  On 7/19/2019 at 12:33 PM, Pity Pat.Patton said:
@2late4u can you point me in the right direction?
Expand
sorry i stay out of radio and navigation and u connect questions to old and to dumb to help there,,good luck there are others that will help sometimes they might not log on every day
  • 2 weeks later...
  On 8/1/2019 at 4:41 PM, DeanC1985 said:
@Kwyjibo Where did you mount everything? I like how it looks like it is pretty well out of sight.
Expand
the amp and aux battery are tucked under the driver seat, there was plenty of room, the line output converter is inside the passenger seat because the factory amp is directly below it easy to tie into, and sub in back
  • 1 month later...
  • 2 months later...
