stormes Posted July 22, 2019 Report Share Posted July 22, 2019 Hi, my car brake suddenly start sinking, at the beginning I had to bush twice, I left the car for two days, the brake completely sank. I left the car for 5 days, the brake starting working as should be. I start driving it more but the brake sank twice only. the dealer connected to OBD2 and got error code C10822f and mentioned it might be caused by ABS or vacuum pump or sensor or brake booster and to know which one they have to inspect the car and I have to pay $120 which I find it is a lot for just checking. I searched online and found the error code C108 is for sensors but I could not find C10822f. any one had the same issue or same error code? Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted July 22, 2019 Report Share Posted July 22, 2019 Not had that problem but, in reality, $120.00 in not a lot when you consider the time and expense of trial and error. Ask the shop if the diagnostic charge is applied toward the repair. Most shops follow that practice. In the end, you have to weight the pros and cons of having the brake system repaired once and working correctly versus your skill and confidence that you can do the task yourself cheaper, and get it correct the first time. Having the correct code and the cost and ease of changing the part yourself vs a shop that you trust and the time that you save. Good luck. jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted July 23, 2019 Official Dodge Support Report Share Posted July 23, 2019 18 hours ago, stormes said: Hi, my car brake suddenly start sinking, at the beginning I had to bush twice, I left the car for two days, the brake completely sank. I left the car for 5 days, the brake starting working as should be. I start driving it more but the brake sank twice only. the dealer connected to OBD2 and got error code C10822f and mentioned it might be caused by ABS or vacuum pump or sensor or brake booster and to know which one they have to inspect the car and I have to pay $120 which I find it is a lot for just checking. I searched online and found the error code C108 is for sensors but I could not find C10822f. any one had the same issue or same error code? Hi stormes, Sorry to hear of the trouble you are experiencing with your Journey. Diagnostic fees are standard practice, fortunately, if your dealer finds that this repair is covered under warranty, the diagnostic fee is covered. If you would like an additional layer of assistance as you work with your dealer for this repair, please feel free to send us a private message as we’re happy to help. Mark Dodge Social Care Specialist jkeaton 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 23, 2019 Report Share Posted July 23, 2019 well you have the option to take it to a brake repair shop that should be able to check it out and they usually will do it with without cost if you have it fixed by them they would probally be cheaper than the dealership jkeaton 1 Quote Link to comment Share on other sites More sharing options...
