Mokoa Posted July 24, 2019 Report Share Posted July 24, 2019 (edited) I have a 2015 Dodge Journey. I do not know what the trim level is. There is no label stating such. The only window that works is the driver's door window. The front passenger window does not work at all. No reaction when using the switch on the front passenger door nor the switch on the driver's door. The two rear passenger widows work once in a while but rarely and they also behave the same when either the switch on the respective rear door is used or the switch on the driver's door is used. What say you all? Edited July 24, 2019 by Mokoa Quote Link to comment Share on other sites More sharing options...
larryl Posted July 24, 2019 Report Share Posted July 24, 2019 Could be a few things low battery, bad drivers door harness or switch, a fuse, bad bcm , bad ground, corrosion etc etc jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
