Yoeman Posted August 8, 2019 Report Share Posted August 8, 2019 Dodge Journey 2012 rt3.6 abs traction and stability dash lights on codes shows left front speed sensor but we replaced it with a new Oem and cleared the code No fix Does the speed sensor pick up from the bearing or cv as I can’t see any tone ring. should I replace the bearing and hub to see if the sensor will work again but the bearing is fine. Ive talked with 3 dealers and not on can tell how the sensor picks up on the wheel speed Wiring to the abs module look go and tests please offer any help Quote Link to comment Share on other sites More sharing options...
Yoeman Posted August 8, 2019 Author Report Share Posted August 8, 2019 Test Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 9, 2019 Report Share Posted August 9, 2019 (edited) how did you determine which wheel it was, mine went bad no codes from it and i dint have a code reader that would read it cost me $58. at the dealership for the part and their labor. guess you replaced the wrong one i would say Edited August 9, 2019 by 2late4u Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted April 28, 2020 Report Share Posted April 28, 2020 (edited) ABS light and traction light on is usual a bad abs sensor! mine said one on the rear was bad! I jacked the car up took each one out (did all 4).. cleaned each sensor with glass cleaner and reinserted each one back into position... dropped back on whee;s.. and light went off before I even got all the way down the driveway! happened 2 years ago been off ever since!!! Edited April 28, 2020 by wpginterceptor Summer Solstice, 2late4u and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 28, 2020 Report Share Posted April 28, 2020 i watched a u tube on cleaning them as well, great that it worked for you and would be a great idea to do before replacing with new ones jkeaton 1 Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted April 29, 2020 Report Share Posted April 29, 2020 (edited) actually no I didn't watach it on youtube.. I just decided I would try cleaning em first before spending the $$ on new ones! I used glass cleaner and then wiped em off.. what did the video use to clean em? again I did this like 3 years ago now and still no issues with ABS or Traction lights.. Today my power steering pump is noisey and ill replace it tomorrow Edited April 29, 2020 by wpginterceptor Quote Link to comment Share on other sites More sharing options...
Hankster Posted April 29, 2020 Report Share Posted April 29, 2020 Before replacing the noisy pump try cleaning or replacing the fluid reservoir. Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted April 29, 2020 Report Share Posted April 29, 2020 2 hours ago, Hankster said: Before replacing the noisy pump try cleaning or replacing the fluid reservoir. think pump is bad.. can smell it burning! and shes whining a little Quote Link to comment Share on other sites More sharing options...
John/Horace Posted April 29, 2020 Report Share Posted April 29, 2020 Level of fluid matters, I fill to the second fill line. Try cleaning/inspecting reservoir like hankster suggested. If it’s a 3.6 engine the pump change will be a challenge, looks like part of exhaust needs removing. I have used suction pump and replaced all the fluid on mine more than once. The additives wear out and there is no filter in system, just a screen usually at bottom of reservoir on most cars left with hydraulics system. Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted April 30, 2020 Report Share Posted April 30, 2020 pump was an ez change on the 2.4! also ran new fluid thru 2late4u 1 Quote Link to comment Share on other sites More sharing options...
