Right park brake not fully releasing
Installed a new RH park brake cable but it is not fully releasing once applied. Lever on caliper is about 1/4" off stop. I can pull it back with my thumb with medium force but it won't return on it's own. I had also replaced the brake caliper and parts store thought it was the problem so replaced the part for me
 The new unit return spring does have more force but I still have the same problem. Tried routing change (not correct installation) to straighten cable into caliper connector and that partially helped but still not returning completely.
Any ideas? Are stronger returns springs available?
I also replaced LH cable but it works fine.
Thanks.
Edited by wrenchpro
Added info
I was hoping that someone would chime in with an idea because I have the same issue. I replaced the RH park brake cable as well, ordered and installed a new caliper lever return spring thinking the original was stretched. Several applications and releases and same result, lever does not return completely to the stop. The right wheel rotates with resistance until the lever is pushed by hand to the stop. So I imagine when driving there is excess friction and heat being generated at the right hand brake pads. My next plan is to install new rear pads and inspect all parts for free movement.
