martyman.geo Posted August 19, 2019 Report Share Posted August 19, 2019 Hi all again! This post is about my 2015 DJ and a change of trans shifting that started occurring about 5 months ago. One note that probably has no bearing on the post or not...lol! is the updating of the remote start. I noticed that the car seemed to have more torque by the amount of front wheel spin occurring from standing start. It almost seems like a rev limiter has been removed. I know this isn’t the case but I have been driving my DJ for almost four years and the change is quite noticeable. Another noticeable item is getting on the freeway accelerating to speed, the revs now go a lot higher than before shifting if I stay on it. I had this same type of experience with a shift kit installed in a th400 trans in a Camaro I used to own. Is this normal for an Awd? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 19, 2019 Report Share Posted August 19, 2019 The transmission will "adapt" to driving style....maybe that has something to do with it. You can reset by disconnecting the battery for 10 minutes or so. Maybe try that and see if it changes anything. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted August 20, 2019 Report Share Posted August 20, 2019 3.6 or 2.4? By revs, I'm assuming that you mean RPMs. What is a lot higher? The limit is the redline at 6500ish RPMs for the 3.6. It's not uncommon for the computer to allow RPMs to go to redline on my 2011 when I'm getting after it. If it's going into the redline, that's a problem. I believe the AWD is actually FWD until a loss of traction is detected. For all intents and purposes, its going to be FWD most of the time. When you say torque, are you referring to torque steer? Camaros are RWD and torque steer is not a thing with those. Torque steer is a characteristic of FWD vehicles at WOT. Try the battery disconnect as jkeaton suggests. If that doesn't help then take it in for a diagnosis. These transmissions don't hold up to intense use. If there is an RPM issue, you need to get it corrected. My transmission failed at about 80K miles. Had it replaced under lifetime warranty. Good Luck. Peace. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
martyman.geo Posted August 29, 2019 Author Report Share Posted August 29, 2019 (edited) Thank you guys for your responses. It is a 3.6 with AWD. I wish I still drove like I used to do. I am that guy that stays at the speed limit on the freeways and streets. Very boring most of the time. Yes, torque steer is what I meant. My old camaro had higher shift points not torque steer. Sorry about the confusion. If I get on it (LOL in my dj ) it pulls or steers to the left. As far as the rpm’s: going on the freeway it holds more of the gears to higher RPM’s more than it did a few months ago. No change on my driving style but noticeable when it runs up to 4500-5000 RPm’s. I am used to a lot lower shift points from when I first started driving it. It has almost 60000 miles now and I will be setting up an appointment at the dealership to do the major maintenance ($600.00) which includes changing the dif oil but not the trans fluid. After reading this post last week, I spoke to the dealers to ask the same question, they mentioned I should bring it in so they can reset the computer for $150.00. ( that seems like there favorite price for everything ) if i can do it myself for free, than I think I could try it out. I will let you all know how it goes. Edited August 29, 2019 by martyman.geo Spelling Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted August 31, 2019 Report Share Posted August 31, 2019 Good luck with your symptoms. Peace. Quote Link to comment Share on other sites More sharing options...
probak118 Posted August 31, 2019 Report Share Posted August 31, 2019 Might be a good idea to think about the 2015 battery too , changed my 2012 couple years ago. Since you will be removing the wheel well cover to reset / disconnecting the battery cables. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
martyman.geo Posted December 29, 2019 Author Report Share Posted December 29, 2019 Had the 60000-mile service done and the DJ seems to be purring like a kitten! I just have one regret, I had replaced the cabin and engine air filters a month before the service. Without reading the fine print, the dealership replaced them for a total cost of $90.00. I should have had an alignment done vice the filters changed Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted December 29, 2019 Report Share Posted December 29, 2019 3 hours ago, martyman.geo said: Had the 60000-mile service done and the DJ seems to be purring like a kitten! I just have one regret, I had replaced the cabin and engine air filters a month before the service. Without reading the fine print, the dealership replaced them for a total cost of $90.00. I should have had an alignment done vice the filters changed Good to hear that things are working so far. Thanks for the update. Hard lesson learned though...know thoroughly what you are being charged for before signing off on the work. We have all done that before somewhere in life. Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 29, 2019 Report Share Posted December 29, 2019 yep they told me one time your cabin air filter is real dirty do you want us to change it i said okay this was on my 2011 and when they charged me $22. for it i said wtf,well that didnt happen any more i went and bought a k-n cabin air filter and when i bought my 2014 i pulled it out of the 2011 and transferred it to my 14 the same thing i did with my engine K-N air filter as well Quote Link to comment Share on other sites More sharing options...
