waltnpam Posted August 28, 2019 Report Share Posted August 28, 2019 Has anyone else had an issue with there AC ? ours out of no where began making noises internally so we had it replaced. The new one after 2 weeks the new one blew hot air. Now mind you we did have everything changed so the second failure was not caused by contaminants from the first. So once again they replaced everything again,it not very impressively works. What I find most strange is now we have lost 2 to 3 mpg! Wondering if anyone else has had similar experience. Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 28, 2019 Report Share Posted August 28, 2019 1 hour ago, waltnpam said: Has anyone else had an issue with there AC ? ours out of no where began making noises internally so we had it replaced. The new one after 2 weeks the new one blew hot air. Now mind you we did have everything changed so the second failure was not caused by contaminants from the first. So once again they replaced everything again,it not very impressively works. What I find most strange is now we have lost 2 to 3 mpg! Wondering if anyone else has had similar experience. there is a lot of parts in an air conditioning unit so just wondering what did you replace all new,,,,,,,,,,,was it the compressor, dryer, the inside unit, blend doors plus many other small parts on a 6 yr old car, sounds like you might have a compressor problem due to mpg loss, hard to tell from here Quote Link to comment Share on other sites More sharing options...
waltnpam Posted August 29, 2019 Author Report Share Posted August 29, 2019 I did not do the work myself so I cant be totally specific however I can say aside from replacing the compressor the dryer and lines related to the flow of refrigerant. Quote Link to comment Share on other sites More sharing options...
