CombatHowie Posted August 29, 2019 Report Share Posted August 29, 2019 This is something new: what could cause all the electronics to quit? There have been times where the vehicle has been running fine and when parked turn it off. Try to restart and only sometimes there are various problems; won't start when the brake pushed and button pressed, inside lights don't turn on and won't start after fob unlocks doors and some times the electric doors won't unlock the doors. Jump start doesn't work. After removing the battery and the auto parts store checked, the battery is good. Reinstalled battery and every thing works fine. The only thing that makes it so it will start is to disconnect and reconnect battery. Why? Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted August 30, 2019 Official Dodge Support Report Share Posted August 30, 2019 Hi @CombatHowie I'm sorry to hear that you have this electronics concern with your Dodge Journey. Have you brought this to the attention of your dealer? If you decide to make an appointment and would like an additional layer of assistance, please feel free to send our team a private message with your VIN, mileage, and dealer. Darlene Dodge Social Care Specialist Quote Link to comment Share on other sites More sharing options...
OhareFred Posted August 31, 2019 Report Share Posted August 31, 2019 I must admit, I am stumped. I would have the battery checked, then the cables. My first thought was a loose connection. check under the under hood power distribution box. They have been reported to corroded.... Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Armando G Posted September 2, 2019 Report Share Posted September 2, 2019 First and only thought... corrosion somewhere in the cables or fuse box. If the battery is fine and the connectors are clean and fit nice and tight, check the other end. If the negative ground looks good, remove it and clean it anyway. Check the main power cable to the fuse box for corrosion. Start there and then move on to search for a faulty connection. greenturtle, OhareFred and Summer Solstice 1 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 2, 2019 Report Share Posted September 2, 2019 like armando said check all the connections at the starter and the neg at the frame a lot have said that was there problem,good luck Quote Link to comment Share on other sites More sharing options...
Armando G Posted September 4, 2019 Report Share Posted September 4, 2019 Guess the problem fixed itself??? Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 4, 2019 Report Share Posted September 4, 2019 2 post wonder jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Howitzer Posted January 19, 2023 Report Share Posted January 19, 2023 On 2019-08-30 at 8:12 PM, OhareFred said: I must admit, I am stumped. I would have the battery checked, then the cables. My first thought was a loose connection. check under the under hood power distribution box. They have been reported to corroded.... How would you do so? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 19, 2023 Report Share Posted January 19, 2023 7 hours ago, Howitzer said: How would you do so? Post is 3 years old...... larryl 1 Quote Link to comment Share on other sites More sharing options...
