Kyle Posted August 30, 2019 Report Share Posted August 30, 2019 Hey everyone. I just purchased a 2012 SXT AWD Journey last week I noticed one day in the drive thru at sonic that the coolant temp was at 230 Farenheit. When I left and started driving home it cooled down to 180. The engine light came on and it said that the thermostat was stuck open. I replaced the thermostat added coolant and all that jazz. It's still doing the same thing. I noticed that the radiator fan will kick on at 230 and then turn off in 5 seconds if that. It never really stays on longer than a few seconds. Any ideas to what my problem is? Also what is the average temp for the journey? Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted August 30, 2019 Report Share Posted August 30, 2019 My understanding is that the thermostat stuck open is not a problem. The thermostat being closed helps the engine warm up and then will open to allow coolant to flow. There must be a temperature senson that triggers the radiator fan. I honestly don't know if the radiator fan is electric. I assume it is based upon your observations. If I was attempting to solve this problem, I'd start by researching a coolant temperature sensor. A quick google search got me this... Quote Link to comment Share on other sites More sharing options...
larryl Posted August 30, 2019 Report Share Posted August 30, 2019 The fan is electric so it must be a problem with a sensor or the fan itself and related connections If you turn the AC on the fan should come on and stay running if the engine is warm Quote Link to comment Share on other sites More sharing options...
