Medelc Posted September 19, 2019 Report Share Posted September 19, 2019 It wont move when i put it on drive or reverse when i press the pedal on drive or reverse its seams like its in neutral. I never had a problem it wasn't slipping or anything like that until now. I went to McDonald's and than it just dont want to move Quote Link to comment Share on other sites More sharing options...
larryl Posted September 19, 2019 Report Share Posted September 19, 2019 It could be so many things......... jkeaton and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
Medelc Posted September 19, 2019 Author Report Share Posted September 19, 2019 14 minutes ago, larryl said: It could be so many things......... I forgot to mention it wont stay in park. I have to put rocks on tire to kept it from moving Quote Link to comment Share on other sites More sharing options...
OhareFred Posted September 19, 2019 Report Share Posted September 19, 2019 Trans is gone....my guess...trans shop or dealer..either way $$$$$$$$ jkeaton 1 Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted September 19, 2019 Report Share Posted September 19, 2019 Cars come with a parking/E brake for this reason. Use the e-brake pedal (left side of driver's foot well) to prevent the car from moving. Doesn't hurt to use brick behind/in-front of the wheels too. Can you turn off, and take the key out of the ignition when the shifter's is in park? (with your foot on the brake): Can the car start? Are you sure the car is in true neutral, and not still in drive? with the engine off, the torque converter will feel like neutral at low speeds. Does the dashboard indicate the PRNDL changing, even though the car seems in neutral? is the electrical system working (radio, headlights, ect) Just for fun, try the old' trick of disconnecting the battery for 30 minutes; See if this gives the transmission a second wind... If it was me, I'd get it on a tow truck and take it to the nearest decent family-owned transmission shop. Might be big repair, but if the car didn't indicate any issues, it might be a issue with the shift lever, or it's push-rod that move the transmission in and out of gear. larryl, Armando G, 2late4u and 2 others 5 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 19, 2019 Report Share Posted September 19, 2019 Moved to the correct section. NavalLacrosse gave you some excellent starting points. Good luck! NavalLacrosse 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 24, 2019 Report Share Posted September 24, 2019 Guess we will never know..... Quote Link to comment Share on other sites More sharing options...
Armando G Posted September 28, 2019 Report Share Posted September 28, 2019 Still waiting for his McDonald's order??? Quote Link to comment Share on other sites More sharing options...
Medelc Posted September 28, 2019 Author Report Share Posted September 28, 2019 I got it fixed. It was the cv intermediate shaft. Quote Link to comment Share on other sites More sharing options...
Armando G Posted September 28, 2019 Report Share Posted September 28, 2019 Thanks for the update. Was it pricey? Did it break under stress? Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 28, 2019 Report Share Posted September 28, 2019 looks like about 40 for one off amazon plus labor Quote Link to comment Share on other sites More sharing options...
