12 PACK Posted September 22, 2019 Report Share Posted September 22, 2019 '15 Journey AWD 3.6 showing code C1502-96, ABS & Traction Control lights are on. Low tire pressure light isn't and tires are @ 42 & 41 psi. Pulled out of the driveway and there's a clunk when going slow, every 50 ft or so. My scanner shows this code meaning TPS 2 Internal: Component Internal Failure. It says it's a common code and a frequent fix in replacing a tire pressure sensor(s). We had new tires put on 4 months ago, now we're at 71K. Bad sensor? Thanks for any input Quote Link to comment Share on other sites More sharing options...
12 PACK Posted September 22, 2019 Author Report Share Posted September 22, 2019 4 minutes ago, 12 PACK said: '15 Journey AWD 3.6 showing code C1502-96, ABS & Traction Control lights are on. Low tire pressure light isn't and tires are @ 42 & 41 psi. Pulled out of the driveway and there's a clunk when going slow, every 50 ft or so. My scanner shows this code meaning TPS 2 Internal: Component Internal Failure. It says it's a common code and a frequent fix in replacing a tire pressure sensor(s). I also have code C003A, Right Rear Wheel Speed Sensor: Signal Compare Failure & Signal Erratic. I had that wheels wheel bearing replaced in July. 4 minutes ago, 12 PACK said: We had new tires put on 4 months ago, now we're at 71K. Bad sensor? Thanks for any input Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 22, 2019 Report Share Posted September 22, 2019 3 hours ago, 12 PACK said: I also have code C003A, Right Rear Wheel Speed Sensor: Signal Compare Failure & Signal Erratic. I had that wheels wheel bearing replaced in July. just had aright front wheel sensor replaced few months ago, only thing my journey showed was the abs and traction control light on also cruise control in op due the traction lights on as well s the abs light....... the wheel speed senor is different than the wheel bearing 2014 with 93 k on it ... dont see how the TPM could be the cause if they are still reading okay...u tube on how to fix the wheel senors or just replace it if you are sure it is bad Quote Link to comment Share on other sites More sharing options...
12 PACK Posted September 22, 2019 Author Report Share Posted September 22, 2019 I think it's the wheel sensor and the wheel bearing and new tires this year are unrelated. Thanks for posting. Quote Link to comment Share on other sites More sharing options...
12 PACK Posted September 24, 2019 Author Report Share Posted September 24, 2019 Turns out the wheel bearing that was replaced two months ago failed. It was replaced under the warranty I got when the job was done. That explains the clunk I heard as I didn't think a failed sensor would cause that. I'm glad I didn't replace the sensor thinking that was the cure. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 24, 2019 Report Share Posted September 24, 2019 Glad you got it fixed. Quote Link to comment Share on other sites More sharing options...
