MoMopar Posted September 25, 2019 Report Share Posted September 25, 2019 I have a 2010 Journey SXT, 3.5 V6. Does anyone have a schematic of the electrical? Since I got it I have had intermittent issues with the electrical, primarily on the drivers side. I have replaced the entire wiring around the headlight twice on that side because it burnt up from to much power going to it. The keyless entry was almost nonexistent on the drivers side, working when you were 2 feet from the door and now not at all. If we lock the door we have to use the key inside the FOB to open it which sets off the alarm; sometimes the alarm will not go off unless we physically start the car and move it 20 to 30 feet. I have replaced the FOB batteries, had the FOBs tested (both test fine), and bought a new FOB just in case. I do not know where the sensor sits inside the car to diagnose if it is the problem but now other electrical components are having issue so I suspect a larger electrical issue. twice the alarms and horn started going off when we weren't even near the vehicle and the keys were hung up. The AC blend air doors have shorted out twice on the drivers side as well. electrical issues are a huge pain so I have been fixing as needed but I think I should find the final solution. Any ideas on where to start diagnosis would be great. Quote Link to comment Share on other sites More sharing options...
NavalLacrosse Posted September 25, 2019 Report Share Posted September 25, 2019 This very well could be contributing to your other issue regarding the driver's AC not working. Electrical issues are where I just sit it out. was this car in a flood? 2late4u and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 26, 2019 Report Share Posted September 26, 2019 Did this just start? Are you the original owner? Quote Link to comment Share on other sites More sharing options...
larryl Posted September 26, 2019 Report Share Posted September 26, 2019 Sounds like the TIPM has gone to the toilet... jkeaton 1 Quote Link to comment Share on other sites More sharing options...
