You might be able to grab the cd with a needle nose pliers, or a straightened paper clip. Hit the eject button while trying to pull it out or lifting the cd.  Likely will trash the cd but should work.  If there is a passer sticker label on the cd don’t use it in the car....
Edited by OhareFred
sounds like the ejection  assy. is out of alignment if you still want the cd player to work run by a stereo shop and let them work on it otherwise you will probally mess it up more yourself by pulling the cd out. the assy get out of  alignment over time from having a cd in 24 -7 and the vibrations of the road traffic
Edited by 2late4u
