HVAC
Atavio
Hello Journey enthusiasts.
Have a black RT/AWD. For whatever reason, the HVAC only delivers air to the front window. Yes, I have dual zone control, and yes I have tried the auto setting, manual setting, and every possible setting fo control the flow of air from the front window to the panels or floor; the air will onyl flow to the front window. That's really jacked, because in the freezing temperatures this winter I need some heat on my feet!
Anyone had a similar problerm and found a solution?
--Atavio--
I don't have that problem, but I thought I recently saw a welcome message from someone in Paris who reported the same thing. I'm not sure what you would do about that. Do the pushbuttons in the center stack respond when you press them i.e. if you direct air to your feet, does that button light up?
Thanks for the reply DP.
Yes, all lights activate to indicate airflow selection for panel, feet, windshield, but the air only bolws at the windshield.
Guess I'll have to takt it to the shop... ... ...
