2010 Facelift?
Sup3rJD
Hello I am receiving a 2010 Dodge Journey in the Deep Water Blue color. I've seen some other other newer Dodge Journey's with the new design and the same color. I was wondering if it is possible to install the 2012 front & rear bumper on to my 2010 Journey. I was also curious if I could get the LED Taillights to work on mine that has the standard incandescent tail lights.
just check with your local dealership on the frt end change and if the parts are interchangeable and just change your bulbs out to led will be the cheaper solution than buying the whole units themselves as they are Expensive and when they quit working they have to be serviced at the dealership only..good luck
