Unlocking the doors
1 minute ago, Artful Dodger said:
I replaced battery 1 month ago
 And not been right since. Any ideas?
are you sure you replaced the fob battery with the correct size and or brand?you are not giving enough info, does it work on the other doors or lift back okay?
18 hours ago, Artful Dodger said:
I replaced the remotes  battery 1 month ago, works manually,  but not by lifting the handle
. Any ideas?
This is confusing.....works manually but not by lifting the handle.....isn't lifting the handle manual? Need to help us help you by clearly explaining your issue.
