N.B. Posted December 2, 2019 Report Share Posted December 2, 2019 Hello, My 2014 Journey R/T will not start. I tried to boost the battery, still nothing. Service Awful sensor on and also shows not in park. Any help is appreciated! Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 2, 2019 Report Share Posted December 2, 2019 your post doesn't make much sense, Is that service awd sensor or what?has the battery been load tested to see if its good by a auto garage ,not meaning we boosted it.assuming its a 3.6 eng?need a lot more info if you want help jkeaton and Armando G 2 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 2, 2019 Report Share Posted December 2, 2019 Did you check to make sure it’s in park? Did you try starting in neutral? Is it cranking or doing nothing? More info needed..... jkeaton, Armando G and 2late4u 3 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted December 2, 2019 Official Dodge Support Report Share Posted December 2, 2019 18 hours ago, N.B. said: Hello, My 2014 Journey R/T will not start. I tried to boost the battery, still nothing. Service Awful sensor on and also shows not in park. Any help is appreciated! Hi N.B, We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support. Rob DodgeCares Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 2, 2019 Report Share Posted December 2, 2019 As OhareFred said, try neutral. If nothing, get the battery checked, check the battery connections, etc, etc... Are you mechanically inclined? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
