Tjlad187 Posted December 13, 2019 Report Share Posted December 13, 2019 My drive side window main switch is making a clicking noise my windows stop working and the window was down I play with the wiring harness at the windows worked then stop then work again I played with it till the windows went up. I seen there is a ton of wires just trying to find a easy way to fix this Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 14, 2019 Report Share Posted December 14, 2019 No easy way to fix wiring. Just a lot of testing, fixing, and/or replacing. Just check if anything is binding on the door, then start disconnecting, checking for corrosion, and cleaning, reconnecting tightly, or replacing. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 14, 2019 Report Share Posted December 14, 2019 I am wondering if it’s the switch. Wiggling the wires may be making contact..... 2late4u 1 Quote Link to comment Share on other sites More sharing options...
Bill W Posted May 16, 2020 Report Share Posted May 16, 2020 Did you ever figure that out? Same problem m. I’m hearing same sound. Bought a new switch, worked for 3 days and now same issue. Odd thing is the new one stays in auto down when I plug in. I plug in the old one and up is the only direction that works?? Quote Link to comment Share on other sites More sharing options...
wpginterceptor Posted August 3, 2020 Report Share Posted August 3, 2020 im having this issue now.. its the wiring where the door meets the car! next time it happens, hold the door wide open and use the switch, then the windows will work... close the door and doesn't work again... Quote Link to comment Share on other sites More sharing options...
JhamB Posted November 26, 2020 Report Share Posted November 26, 2020 Sounds like a connection or a ground in the wiring from the door to the body. I have seen this issue before but I am not sure what wire it would be. Quote Link to comment Share on other sites More sharing options...
