dragonaut Posted December 18, 2019 Report Share Posted December 18, 2019 hi! All the controls in the steering wheel stopped working, including the horn. The dealer wants to charge 200+ to replace all the controls but it sounds like a blown fuse to me. Does anyone know if there's one fuse for all the controls and where to find it? Thanks! Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 18, 2019 Report Share Posted December 18, 2019 sounds a lot like its the clock spring, but could be something else but no its not a fuse as all the different thins have different fuses...good luck and report back on what you find larryl, Grendi, Armando G and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
Armando G Posted December 19, 2019 Report Share Posted December 19, 2019 From experience, if your horn is out it is probably your clock spring. You can test your horn by connecting a wire to the positive wire and touching your positive tower on the battery. If it beeps, then it's not a fuse or wiring - it's your clock spring. If it doesn't beep, then the challenge begins... start checking wires. Replacing your clock spring is not hard, just time consuming and you need special tools to remove the steering wheel. Tools can be rented. 2late4u and Grendi 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 19, 2019 Report Share Posted December 19, 2019 1 hour ago, Armando G said: From experience, if your horn is out it is probably your clock spring. You can test your horn by connecting a wire to the positive wire and touching your positive tower on the battery. If it beeps, then it's not a fuse or wiring - it's your clock spring. If it doesn't beep, then the challenge begins... start checking wires. Replacing your clock spring is not hard, just time consuming and you need special tools to remove the steering wheel. Tools can be rented. check out u tube vidios on replacing clock springs and also price one from a mopar discount on the internet Quote Link to comment Share on other sites More sharing options...
km-04 Posted December 19, 2019 Report Share Posted December 19, 2019 Here is just one of many out there... 2late4u and Grendi 2 Quote Link to comment Share on other sites More sharing options...
Grendi Posted April 17, 2021 Report Share Posted April 17, 2021 thanks for the info. I had the same problem after replacing the clock spring the horn and evic control worked again. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 17, 2021 Report Share Posted April 17, 2021 thanks for responding back as dragonaut did not report back, important for others to learn and try to fix their journeys, welcome to the group Quote Link to comment Share on other sites More sharing options...
