Arenivas Posted December 19, 2019 Report Share Posted December 19, 2019 I am having such a hard time trying to figure this one out. I got the Code P0732(Gear 2 incorrect ratio) about 3 weeks ago. It stayed on for 2 days and it went away. I have never experienced any slipping or anything like that. Today on my way home it turned on again. This time i was going up a slight hill and felt a sudden stutter. There are no other codes coming out but that one. Ive done research and that code usually appears with other codes. The Journey drives perfectly fine. Im thinking maybe its the cold weather? Im so confused. Any suggestions would help. Thank you. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 19, 2019 Report Share Posted December 19, 2019 I can just about guarantee it’s not the cold weather. More likely a transmission issue. You may want to have a trans specialist look at it sooner rather than later.... 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 19, 2019 Report Share Posted December 19, 2019 well no info on age of journey or miles, might be low on fluid, but you should run it by your local trans,service shop and let them see what you have going on,good luck and report back on what you find out Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted December 19, 2019 Official Dodge Support Report Share Posted December 19, 2019 On 12/19/2019 at 2:17 AM, Arenivas said: I am having such a hard time trying to figure this one out. I got the Code P0732(Gear 2 incorrect ratio) about 3 weeks ago. It stayed on for 2 days and it went away. I have never experienced any slipping or anything like that. Today on my way home it turned on again. This time i was going up a slight hill and felt a sudden stutter. There are no other codes coming out but that one. Ive done research and that code usually appears with other codes. The Journey drives perfectly fine. Im thinking maybe its the cold weather? Im so confused. Any suggestions would help. Thank you. Expand Hi Arenivas, We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support. Rob DodgeCares Quote Link to comment Share on other sites More sharing options...
