No Heat Passenger Side
SCamp4
Hi all,
I have a 2010 Journey with no heat coming from the passenger side. I changed the blend door cause it was clicking and that did not fix it. I flushed the coolant system and still no heat. Is this probably a heater core issue? Most of what I've read has led me to think this has been a very common problem for this year of the journey. Thank you for the input. Also does anyone know where I can get the layout of all coolant hoses some shady mechanic had removed all the hoses going to the rear heater core.
This is in response to the original post but may be relevant to the second post.
If the blend door, heater core, and thermostat have been ruled out or repaired AND you have flush and refilled the system but still have no heat, you may have an air bubble in the line or core. It is a common problem that can happen on any vehicle.
Edited by Summer Solstice
  • Official Dodge Support
On 1/10/2020 at 2:17 PM, yantic_fire said:
I'm having the same issue... anyone that can help please
Hi yantic_fire, We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support.
Rob
DodgeCares
