09RT Posted January 12, 2020 Report Share Posted January 12, 2020 My 2009 3.6L Journey has sat for about 3 years now. When it was parked, it had about 3/4 of a tank of gas in it, so there should still be about that much in the tank that definitely needs replaced. I found a couple of videos online: How To Recover Gas From A Dead Car Dodge Journey How To Disconnect Fuel Line I'm in the dark on newer fuel systems, so can someone either correlate those two videos or explain how I could jump the Journey's fuel pump to drain the system (if that's safe / won't damage the pump) or if there is another safer / preferred method, what the process for that is on my specific model Journey. Thanks! Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted January 12, 2020 Report Share Posted January 12, 2020 You can rent or buy a fuel siphon kit for between 10-15 dollars. No experience but a quick Google search came up with a lot of options from various retailers. OhareFred and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
