ZXBoy Posted January 13, 2020 Report Share Posted January 13, 2020 Hey people, Im having an issue with my 2013 DJ with the fogging up of all the windows. I turn on the defrost and it unfogs the windows a little but the side and rear windows stay foggy. Heat and temp is blowing is fine, I have checked to see if the HVAC drain was plugged up and it was fine, I can't see any water leaking inside the cabin so I don't think there is a heatercore leak. Sometimes i do smell a funny musty smell when I change over from defrost. It is not coolent that I'm smelling, I know what that smells like. It's like water is somehow in the vent system and causing the fogging, It's just like a heatercore problem but I dont smell any coolent. Any idea's?? Thanks Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 13, 2020 Report Share Posted January 13, 2020 (edited) this has been discussed before, check and read thur the forum section .......................Moisture Issue Won't Defog ....type this in the search bar hope it helps Edited January 13, 2020 by 2late4u ZXBoy, Armando G and OhareFred 2 1 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted January 13, 2020 Official Dodge Support Report Share Posted January 13, 2020 On 1/13/2020 at 4:51 PM, ZXBoy said: Hey people, Im having an issue with my 2013 DJ with the fogging up of all the windows. I turn on the defrost and it unfogs the windows a little but the side and rear windows stay foggy. Heat and temp is blowing is fine, I have checked to see if the HVAC drain was plugged up and it was fine, I can't see any water leaking inside the cabin so I don't think there is a heatercore leak. Sometimes i do smell a funny musty smell when I change over from defrost. It is not coolent that I'm smelling, I know what that smells like. It's like water is somehow in the vent system and causing the fogging, It's just like a heatercore problem but I dont smell any coolent. Any idea's?? Thanks Expand Hi ZXBoy, I do apologize for the trouble you are experiencing with your Journey. We understand you are reaching out to fellow forum members, however if you are not able to remedy this concern with the advice provided here, I kindly recommend connecting with your local Dodge dealer. Rob DodgeCares ZXBoy 1 Quote Link to comment Share on other sites More sharing options...
Armando G Posted January 14, 2020 Report Share Posted January 14, 2020 The only reason I know of this happening in a car is moisture. If you are 100% sure it's not the heater core, look at other options. Leak in the back door, leak in the sunroof (if you have one), door seals ripped... it could be any of those as well. jkeaton, ZXBoy and OhareFred 1 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 14, 2020 Report Share Posted January 14, 2020 i also remember them talking about a sensor i think its the one above the rear view mirror that controls humidity in the journey jkeaton 1 Quote Link to comment Share on other sites More sharing options...
yyz Posted January 21, 2020 Report Share Posted January 21, 2020 The recirculate door is stuck and not bringing in fresh air.It's behind the glovebox where the cabin filter sits. jkeaton, ZXBoy and Mcgusto82 2 1 Quote Link to comment Share on other sites More sharing options...
Hankster Posted January 21, 2020 Report Share Posted January 21, 2020 Check the storage bins in the rear seat floor for water. Pull the front door sill trim then feel under the carpet for water. I had this issue and had water pooling under the carpet. On mine the top of the carpet was still dry to touch. I had to repair a leak then remove the carpet to dry it. Hank Quote Link to comment Share on other sites More sharing options...
probak118 Posted January 22, 2020 Report Share Posted January 22, 2020 On 1/21/2020 at 5:24 PM, Hankster said: Check the storage bins in the rear seat floor for water. Pull the front door sill trim then feel under the carpet for water. I had this issue and had water pooling under the carpet. On mine the top of the carpet was still dry to touch. I had to repair a leak then remove the carpet to dry it. Hank Expand If I may clarify, I think Hankster is saying you should also check the door weather seal conditions and rear floor storage bin areas edges are still working / making a good seal ? Quote Link to comment Share on other sites More sharing options...
Hankster Posted January 22, 2020 Report Share Posted January 22, 2020 Actually mine had water leaking in through the wiring harness push pin holes on the inside of the rocker panel. Had to seal up gaps in the body sealer on the bulkhead area. The water ran down into the rocker panel. The drains were stopped up with sound deadening foam, causing the water to leak into the car. Hope this helps. Hank Quote Link to comment Share on other sites More sharing options...
Hankster Posted January 22, 2020 Report Share Posted January 22, 2020 On 1/22/2020 at 11:10 AM, probak118 said: If I may clarify, I think Hankster is saying you should also check the door weather seal conditions and rear floor storage bin areas edges are still working / making a good seal ? Expand The only way you can get under the carpet is to pull the threshold trim. Hank Quote Link to comment Share on other sites More sharing options...
ZXBoy Posted January 23, 2020 Author Report Share Posted January 23, 2020 Well thank you all for your great advice, the winner here is YYZ!! I pulled apart the recirculate motor and tested, (pain in the butt to get out with no stubby) that seemed to be working and not a stripped gear like some had suggested. When I was running all the vents I was almost sure that I saw the recirculate door not working. So anyway I put it all back together and to my amazement everything worked fine! so like YYZ stated the door must have been stuck and not bringing fresh air into the car. After a long test drive ZERO fogging in the car now! So we can add another fix to this repetitious problem. Thanks again for eveyone's input, twinx1649, Mike313, Summer Solstice and 3 others 1 1 1 3 Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 23, 2020 Report Share Posted January 23, 2020 thanks for replying what fixed your problem , the next guy will know where to check first ZXBoy and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
yyz Posted January 24, 2020 Report Share Posted January 24, 2020 (edited) Glad you got it fixed.We have the same year Journey and I ran into this almost a year ago. I replaced the actuator but when I pulled the old one and just plugged it into the wiring harness it seemed to work. Some people report that tapping them can "wake them up" but there are 3 in the vehicle all the same so now I have a spare. Edited January 24, 2020 by yyz twinx1649, Summer Solstice, jkeaton and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
awp Posted December 9, 2020 Report Share Posted December 9, 2020 Having same issue. No moisture and all windows fogging up. Before I get too expensive with mechanics where is this re-circulate door specifically located. Pulled out cabin air filter and don’t see anything obvious. Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 9, 2020 Report Share Posted December 9, 2020 underneath the cabin filter just put your legs at the ceiling and your head on the floor by the firewall its a small black box that turns the shaft that the door is on, also check out you tube videos on dodge journey blend doors inop. there are 3 of them Quote Link to comment Share on other sites More sharing options...
awp Posted December 9, 2020 Report Share Posted December 9, 2020 Thanks for the info. I’ll have a look. Have good heat control on both sides and blows good through all vents just can’t keep from heavy fog from forming. Hoping it’s just door stuck and not allowing any outside air in to mix Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 10, 2020 Report Share Posted December 10, 2020 On 12/9/2020 at 5:42 PM, awp said: Thanks for the info. I’ll have a look. Have good heat control on both sides and blows good through all vents just can’t keep from heavy fog from forming. Hoping it’s just door stuck and not allowing any outside air in to mix Expand dont forget that black box at the top of your windshield behind the mirror as it has something to do with moisture as well Quote Link to comment Share on other sites More sharing options...
Hankster Posted December 10, 2020 Report Share Posted December 10, 2020 Take a look to see if the under floor storage bins have water under them. Hank Quote Link to comment Share on other sites More sharing options...
awp Posted December 11, 2020 Report Share Posted December 11, 2020 No water anywhere or under the storage bins. Thinking it’s something out of my spectrum to fix at this point. Don’t thing A/C was working up to snuff near end of summer. Would low a/c refrigerant level cause fogging? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 11, 2020 Report Share Posted December 11, 2020 (edited) Yes, absolutely. Good observation. Can be topped up inside a heated shop with refrig and leak fixed. I believe in extreme cold a/c is disabled to protect it, but it really helps remove humidity in winter a lot of the time. If you have auto climate, leave the windshield defrost button lit up on dash, don’t turn it off. Edited December 11, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
awp Posted December 11, 2020 Report Share Posted December 11, 2020 I’ll get it topped off and see if that does the trick! 2late4u 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted December 12, 2020 Report Share Posted December 12, 2020 Would leaving the front defrost button activated not override the other options like floor, front panels etc ? It just seems to me when defrost is on, all air is directed only to that output; no floor / front panel heating. Maybe I am wrong, going to have to test that out next cold day. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 12, 2020 Report Share Posted December 12, 2020 I think there is an option for floor and defrost, but I may be thinking about my Jeep. Just leave mine on auto and forget about it ? Quote Link to comment Share on other sites More sharing options...
awp Posted December 12, 2020 Report Share Posted December 12, 2020 It doesn’t matter what setting I have it on. Defrost only or mixing it. Fogging happens no matter what. I’ve had to resort to driving with windows down a crack to get some outside air in which helps with the fogging....but makes for a cold ride Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 12, 2020 Report Share Posted December 12, 2020 Since you checked everywhere for water and didn’t find any wetness, I would have the ac checked. Sounds like that may be a big part of the issue... Quote Link to comment Share on other sites More sharing options...
