LJ_canada Posted January 20, 2020 Report Share Posted January 20, 2020 Hey guys need some help 2015 DJ front blows heat great both sides no issues the rear (2nd and 3rd rows) have no heat. can turn on the controls and do it from the front or choose to turn it on from the back and turn the heat to high and it’s freezing. not even warm.... it’s cold so unless the front is on highest fan option with heat set to highest all the windows in the vehicle will fog up except the front. if you try to put it on front and floor then even the front can’t keep up because the rear is just pumping out freezing cold air. no leaks in the door seals When driving it the other day the back of my arms and head was freezing and my front was sweating. really odd to me looking for some help before I have to go to the dealer and pay a fortune. thanks in advance Quote Link to comment Share on other sites More sharing options...
OhareFred Posted January 20, 2020 Report Share Posted January 20, 2020 Did you check your coolant level? If you have 3 zone heating there is a separate heater core in the back. Do you have anything leaking from under the car? The hoses for the rear heat are low. Any wet carpet anywhere? Not sure if there is a separate blend door control for the rear. Could be any of these or a combination of all......dealer may be your best bet before you start guessing and replacing parts. The rear heater hose assembly is about $500.... Summer Solstice, larryl and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
Summer Solstice Posted January 20, 2020 Report Share Posted January 20, 2020 Good suggestions above. As stated, it may be worth paying for a firm diagnosis before just throwing parts at it yourself. Even if you do a self-repair, hopefully you can find out exactly where the problem is first. The coolant level is the place to start. jkeaton and OhareFred 1 1 Quote Link to comment Share on other sites More sharing options...
walterfw Posted April 17, 2020 Report Share Posted April 17, 2020 I have the same issue. Where is located the coolant level of the rear heat? Quote Link to comment Share on other sites More sharing options...
LJ_canada Posted April 17, 2020 Author Report Share Posted April 17, 2020 I took the whole side panel off and still couldn’t find the issue..... the front of the vehicle under the hood has the proper amount of coolant. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 17, 2020 Report Share Posted April 17, 2020 16 hours ago, walterfw said: I have the same issue. Where is located the coolant level of the rear heat? Only 1 place for coolant level- well two actually- the radiator and the plastic reservoir. Make sure both are at the full levels. Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 17, 2020 Report Share Posted April 17, 2020 12 hours ago, LJ_canada said: I took the whole side panel off and still couldn’t find the issue..... the front of the vehicle under the hood has the proper amount of coolant. Well, if your not losing fluid under the car, near the firewall, I would venture to guess maybe the rear heater core is plugged or air locked. Might want to try a radiator shop or the dealer. Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
walterfw Posted April 18, 2020 Report Share Posted April 18, 2020 1 hour ago, OhareFred said: Only 1 place for coolant level- well two actually- the radiator and the plastic reservoir. Make sure both are at the full levels. But if the level are lower, the engine doesn't should be heating up? My temperature levels are ok, and I have heat only in my side. The passenger side and rear climate doesn't have heat, only blow up the fan. Quote Link to comment Share on other sites More sharing options...
walterfw Posted April 18, 2020 Report Share Posted April 18, 2020 Ans also I forgot to tell. In my carpet side is a couple humid of water. Should be the core? If so, anyway, where is located the core of the rear climate? Mine AC on the rear also doesn't work Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 18, 2020 Report Share Posted April 18, 2020 (edited) Sounds like your heater core. If you are going to replace it yourself look at the UTube short cuts Your engine won’t run hot until your pretty low, long after no heat. Edited April 18, 2020 by OhareFred Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
Hshelton Posted December 27, 2024 Report Share Posted December 27, 2024 I just got my journey back from the shop, took it in because it would not warm up unless driving and absolutely no warm air blowing in the rear seats. They replaced the water pump and the thermostat now the heat works wonderfully in the front and warms up without having to be driven, but the backseat is still blowing cold air. Just wondering if this could possibly be a common fix I can do or if I need to return to the shop and shell out even more money. Sidenote: in the rear, the air blows really well just not warm so highly unlikely if there’s an issue with the motor or a clog Quote Link to comment Share on other sites More sharing options...
John/Horace Posted December 28, 2024 Report Share Posted December 28, 2024 Is the big tee fitting under hood that sends the glycol to the rear core getting quite hot, big hose probably 2" diameter. Tricky to bleed the air out of a two heater core system. Try another air bleed from the plastic bleeder screw on the thermostat housing under hood. Don't over tighten, plastic is fragile and can be damaged. Quote Link to comment Share on other sites More sharing options...
yyz Posted December 29, 2024 Report Share Posted December 29, 2024 23 hours ago, John/Horace said: Is the big tee fitting under hood that sends the glycol to the rear core getting quite hot, big hose probably 2" diameter. Tricky to bleed the air out of a two heater core system. Try another air bleed from the plastic bleeder screw on the thermostat housing under hood. Don't over tighten, plastic is fragile and can be damaged. Trust me buy a brass bleeder screw you'll thank me later. Quote Link to comment Share on other sites More sharing options...
