Scotiangold Posted January 26, 2020 Report Share Posted January 26, 2020 My Journey threw codes the other day. P0300 and p0340 and started running rough. I shut it off and restarted the car and it was fine for a few minutes but happened again shortly later. I replaced the crank sensor, cleared the code and it was fine for the rest of the day. Today, same symptoms and misfires but now it’s P0365. Camshaft sensor. Coincidence? Sign of another problem? Ideas? i plan to get the camshaft sensor, but I’m also worried it’s something else. On a side note, my battery needs replacing. Could this cause codes like this? Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 26, 2020 Report Share Posted January 26, 2020 well if you think you need a new battery by all means go ahead and replace it as journeys act crazy with low to bad battery's , but i would assume you have a different problem then the battery Summer Solstice and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted January 29, 2020 Official Dodge Support Report Share Posted January 29, 2020 (edited) On 1/25/2020 at 10:48 PM, Scotiangold said: My Journey threw codes the other day. P0300 and p0340 and started running rough. I shut it off and restarted the car and it was fine for a few minutes but happened again shortly later. I replaced the crank sensor, cleared the code and it was fine for the rest of the day. Today, same symptoms and misfires but now it’s P0365. Camshaft sensor. Coincidence? Sign of another problem? Ideas? i plan to get the camshaft sensor, but I’m also worried it’s something else. On a side note, my battery needs replacing. Could this cause codes like this? Hi Scotiangold, We certainly understand why this may be concerning. We understand you are reaching out to fellow forum members, however if you are not able to remedy this concern with the advice provided here, I kindly recommend connecting with your local Dodge dealer. If you end up addressing this with your local Dodge dealer, please let us know via PM. We'd be more than happy to provide you with an additional layer of assistance for that process. Rob DodgeCares Edited January 29, 2020 by DodgeCares Quote Link to comment Share on other sites More sharing options...
Scotiangold Posted January 30, 2020 Author Report Share Posted January 30, 2020 On 2020-01-25 at 11:48 PM, Scotiangold said: My Journey threw codes the other day. P0300 and p0340 and started running rough. I shut it off and restarted the car and it was fine for a few minutes but happened again shortly later. I replaced the crank sensor, cleared the code and it was fine for the rest of the day. Today, same symptoms and misfires but now it’s P0365. Camshaft sensor. Coincidence? Sign of another problem? Ideas? i plan to get the camshaft sensor, but I’m also worried it’s something else. On a side note, my battery needs replacing. Could this cause codes like this? Update: I replaced the camshaft sensor and battery but it’s still doing it. The strange thing is if I pull over, turn off the key and restart the car, it runs find for a minute or so before the misfires come back and I have to pull over again, so I don’t think it’s the injectors or plugs, or it would run poorly all the time. Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 31, 2020 Report Share Posted January 31, 2020 was just reading that on some engines after installing a crank shaft senor it has to be relearned or calibrated this might be your problem Quote Link to comment Share on other sites More sharing options...
