Sean Posted February 7, 2020 Report Share Posted February 7, 2020 ABS, traction control, service AWD, lights are all on most of the time Quote Link to comment Share on other sites More sharing options...
larryl Posted February 7, 2020 Report Share Posted February 7, 2020 Is that good or bad? Summer Solstice and Armando G 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 7, 2020 Report Share Posted February 7, 2020 probally a wheel speed sensor gone bad only dealership and bigger garage will be able to hook their scanners up to check which one is bad, the good thing the parts are around 30-50 each if that is what is wrong... Quote Link to comment Share on other sites More sharing options...
Sean Posted February 8, 2020 Author Report Share Posted February 8, 2020 (edited) Thanks that might make sense considering the tire pressure light is on registering the driver’s side rear tire to be low, but it’s not I check it frequently , also the airbag light is on Edited February 8, 2020 by Sean Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 8, 2020 Report Share Posted February 8, 2020 On 2/8/2020 at 3:40 PM, Sean said: Thanks that might make sense considering the tire pressure light is on registering the driver’s side rear tire to be low, but it’s not I check it frequently , also the airbag light is on Expand no.... its not connected to the tpms, sensor,,,, also with these lights on your cruise control wont work as well,i had thoes lights on as well but the car part stores scanners cant tell you which wheel is bad IF that is your problem, mine was the drivers front wheel that was bad ,,dealer was already doing some maintenance work on it and they fixed it for about $59 for the part and labor,, but my air bag light was not on Quote Link to comment Share on other sites More sharing options...
Sean Posted February 11, 2020 Author Report Share Posted February 11, 2020 (edited) Now the car is having what feels like a transmission problem after it starts and on first acceleration ( only if all those lights are on) and then it’s fine...guessing it’s connected to the lights Edited February 11, 2020 by Sean Quote Link to comment Share on other sites More sharing options...
larryl Posted February 11, 2020 Report Share Posted February 11, 2020 Hows the Battery Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 11, 2020 Report Share Posted February 11, 2020 On 2/11/2020 at 3:28 PM, Sean said: Now the car is having what feels like a transmission problem after it starts and on first acceleration ( only if all those lights are on) and then it’s fine...guessing it’s connected to the lights Expand if its a wheel sensor going bad,your abs braking will not work you will still have brakes but not the anti skidding option, also as i said before your cruise control wont work with these lights on but this should not effect the transmission operation Quote Link to comment Share on other sites More sharing options...
Sean Posted February 11, 2020 Author Report Share Posted February 11, 2020 After the car starts and the lights come on ,, there is no power to the wheels,,then it feels like a downshift with a shutter sound I can feel it abruptly and everything is fine until the car is off and starts back again Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 11, 2020 Report Share Posted February 11, 2020 (edited) run it by your local transmission garage they can scan it to see if they can fix it, usually no charge to just scan it but the dealership will charge. but you need to get it scanned to see what is causing the lights to come on and then address your other problem as well.good luck by the way is it a FWD or AWD? mine is a fwd so maybe if it is awd maybe that does affect the transmission Edited February 11, 2020 by 2late4u jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 11, 2020 Report Share Posted February 11, 2020 Need to get it scanned for codes as suggested. Otherwise we are all just guessing. Quote Link to comment Share on other sites More sharing options...
Sean Posted February 11, 2020 Author Report Share Posted February 11, 2020 (edited) AWD I agree with getting scanned and in regards to the battery it is 5 yrs old ... maybe that plays a role thanks everyone Edited February 11, 2020 by Sean jkeaton and 2late4u 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted February 12, 2020 Official Dodge Support Report Share Posted February 12, 2020 On 2/11/2020 at 8:47 PM, Sean said: AWD I agree with getting scanned and in regards to the battery it is 5 yrs old ... maybe that plays a role thanks everyone Expand Hi Sean, We see that you have received some great advice from your fellow forum members! However, if these suggestions do not address your concern and you decide to visit your dealer, our team would be happy to offer additional assistance throughout that process. We are available via private message! Rob DodgeCares Quote Link to comment Share on other sites More sharing options...
