I have a 2012 Dodge journey with the 8.4n radio with navigation (hence the n). Could someone verify the correct telematics module part number for me? It was quoted as the 68222279aa but by Vin at the dealerships it's the 68222278aa one, which is two hundred more dollars. They told me the 78aa would not work. I just want to know if they are trying to con me for a more expensive part...thanks..
i doubt the dealership is trying to con you if the vin calls for the higher price one ten that should be the part you need ,try calling a different dealership to see what they tell you or even better look at your old part to see what is printed on it as well...good luck and report back on what ever you find out
