jazzyjay430 Posted February 16, 2020 Report Share Posted February 16, 2020 Need help my manual journey starts fine but I put it in gear no drive could it be 100%clutch issue Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 16, 2020 Report Share Posted February 16, 2020 would guess so Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 16, 2020 Report Share Posted February 16, 2020 Look at the the two half shafts on the front wheels, make sure the boots are fine and not twisted. If a c/v shaft comes apart internally the wheels won’t move the car, but part of the shaft will still spin. Very rare type of failure to happen. If rpms are climbing and no movement, friction disc on clutch or pressure place probably worn out. Could raise front of car with both wheels up, engage in gear with car running and see if one wheel spins with no weight on it. This would confirm clutch slipping, or if grinding noise differential side gears in tranny bad. Summer Solstice 1 Quote Link to comment Share on other sites More sharing options...
