Can I mount 20x10 -18 mm offset 255 40 20 on 19 journey without problem
Clintw
  • 9 months later...
5x5(5x127)
Offset Range: 25 to 45
Wheel Size Range: 17X7.5 to 22 X 9
OEM Tire Size:                                           225/55-19(225X730 mm)                                          225/65-17(225X724 mm)
Hub Diameter: 71.5
Thread Pitch:
I'm thinking that -18 offset is gonna put that tire way outside the fender line (unless thats what you want) but it can also make serious rubbing issues, alignment headaches and quickly wear out wheel hubs.
12x1.50mm
