Seb Posted February 20, 2020 Report Share Posted February 20, 2020 I have a 2014 Dodge Journey R/T AWD with190 000 Kilometers...I just had an Intake Camshaft replaced along with a roller rocker. My car was misfiring before the change randomly. After the change of camshaft and roller rockers it stopped misfiring and the codes are gone. I also changed the spark plugs and coils, new air filter and battery. An oil change was performed on the Journey 1 month before the camshaft was replaced. As my camshaft was being replaced I added an oil cleaner and a transmission fluid repair. Now after driving the car only 1 day and a few kilometers it started driving different like it's vibrating. Then the engine light came on.I took to my mechanic to check the code and it came up P06DD. Oil pressure sensor. He resented the codes and I went home.Then after about 50 kilometers later the car started going on limp mode and light came back on. It did it 3 times. I stopped the vehicle after pulling over because I was on the highway. The light went off. On my way back about half way through the light came back on and it went to limp mode again. I stopped driving it and will be changing the sensor. I was wondering if anyone had this problem with the same symptoms? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20, 2020 Report Share Posted February 20, 2020 what do you mean....added an oil cleaner and a transmission fluid repair? are you saying a oil change and a transmission fluid and filter service...usally when they go into limp mode it is a transmission problem, good luck Quote Link to comment Share on other sites More sharing options...
Seb Posted February 20, 2020 Author Report Share Posted February 20, 2020 no it's an add-on fluid. Transmission repair fluid and oil cleaner add on. The engine light code is po6dd and with the Chrysler manual. Code means oil pressure sensor failure the transmission seems fine it shifts gears no problem and it's not as if hating limp mode is not only for transmission failures Quote Link to comment Share on other sites More sharing options...
Seb Posted February 20, 2020 Author Report Share Posted February 20, 2020 I meant to say it's not hesitating the transmission that is Quote Link to comment Share on other sites More sharing options...
Seb Posted February 20, 2020 Author Report Share Posted February 20, 2020 The transmission is not hesitating it doesn't shift hard Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 20, 2020 Report Share Posted February 20, 2020 Maybe your oil additive plugged the filter? Quote Link to comment Share on other sites More sharing options...
Seb Posted February 20, 2020 Author Report Share Posted February 20, 2020 My mechanic was thinking the same thing Quote Link to comment Share on other sites More sharing options...
Seb Posted February 20, 2020 Author Report Share Posted February 20, 2020 Well I'm going to change a sensor anyway and a filter to a Mopar filter Quote Link to comment Share on other sites More sharing options...
Seb Posted February 20, 2020 Author Report Share Posted February 20, 2020 Do you know if that would cause the vehicle to go into limp mode Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20, 2020 Report Share Posted February 20, 2020 had a older caravan that went into limp mode it was a transmission sensor, cost me about 350$ u.s. no telling which one they will have to scan it and see.good luck Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20, 2020 Report Share Posted February 20, 2020 2 hours ago, Seb said: no it's an add-on fluid. Transmission repair fluid and oil cleaner add on. The engine light code is po6dd and with the Chrysler manual. Code means oil pressure sensor failure the transmission seems fine it shifts gears no problem and it's not as if hating limp mode is not only for transmission failures i never use all the oil additive or seal treatments being hawed and sold Summer Solstice and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
