kiwiinsask Posted February 20, 2020 Report Share Posted February 20, 2020 Hi , new to forum , so , im up in canada ...my 2012 has the power steering leak , already had the recall in 2016 ... i read somewhere there was an updated return hose , but i cant find a part number , i did a search on here and only found a thread on changing the brake fluid to a full syn fluid ... has anyone in the more fridgid climates had an upgraded hose ? or because 8 months of the year is cold , how about deleting the cooler as it appears to be a weak link .... any ideas ? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20, 2020 Report Share Posted February 20, 2020 well the dealership will have the updated hose # welcome to the group Quote Link to comment Share on other sites More sharing options...
kiwiinsask Posted February 20, 2020 Author Report Share Posted February 20, 2020 was hoping that rock auto had the hose as it will be 90% cheaper than a dealer .. was after the part number or description ideally , and thanks fo the welcome Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 20, 2020 Report Share Posted February 20, 2020 seeing that you are from Canada where the cold gets so bad i would take the hose down to a hydraulic hose shop or garage and see if they could make you one up so it would be better than anything you could get from rock auto or dealership,,,take care kiwiinsask 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted February 20, 2020 Report Share Posted February 20, 2020 Why not contact the Dealer as the faulty hose was a "recall" hose that was supposed to fix the issue? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted February 21, 2020 Report Share Posted February 21, 2020 (edited) Actually rockauto sells lots of oem stuff from Mopar, Ford , AC Delco etc. The return hose with the oil cooler fin section is on their site. Mopar part shows two different numbers listed for part they are selling. Not sure if it’s new part or not. Several other after market vendors like Gates on there as well. https://www.rockauto.com/en/catalog/dodge,2014,journey,3.6l+v6,3300354,steering,power+steering+return+hose,7324 My 2014 hose was changed in 2018 at 123kms by dealer no charge. I would approach them about changing it under recall again, worth a try. Go to Transport Canada government site and report second failure if they don’t replace it. Princess Auto does custom hydraulic work I believe. If you bring them old one they might be able to come up with something. Edited February 21, 2020 by John/Horace Quote Link to comment Share on other sites More sharing options...
kiwiinsask Posted February 22, 2020 Author Report Share Posted February 22, 2020 cheers guys , the dealer said no to a new hose again , it had the recall done already in 2016 ... i asked the dealer what upgraded part they use , he told me they just use the factory part , so i said "well that part will fail again wont it ? " and he said yes ...... what a friggin joke , have ordered the hoses from rock auto , high pressure and low pressure return as bot appear to be leaking , also can just see the pump has a small leak as well .. but that looks harder than hell to replace , also the tans cooler lines are leaking as well ... though not so important . jkeaton and 2late4u 1 1 Quote Link to comment Share on other sites More sharing options...
