SkinnyFatMan Posted March 7, 2020 Report Share Posted March 7, 2020 Im looking for a cam sensor diagram for a 3.6l 2015 Dodge Journey. These have a "Unique" 2in1 Cam sensor, 4 pin/way. I decided to do a rocker arm repair, got it back together and now am getting a p0349 Cam Position Bank 2 Sensor 1 Intermittent. I pulled the sensor plug off and also got a p0390 Cam Position Sensor 2 Bank 2 Intermittent. That narrowed it down to the intake side of the cam sensor and its brand new. Took voltage readings today with a back probe. Readings are as follows. Pin 1-4, 4 is towards driver. 4 to 3, 2.5-2.7V you can see the notches on the toner ring. 4 to 2, 2.2-2.4V you can see the notches on the toner ring. 3 to 2, 5V non variating, I think this is the signal voltage in. 1 to any. Dead. Not registering any or very little voltage. Engine had all cams removed for a topside overhaul of all rockers and lifters plus a new intake cam on bank 1 due to failed rocker destroying a lobe. Engine to TDC #4 to facilitate repairs as per manual. Can be one or four. With bank two alignment arrows parallel to valve head. Bank one alignment lines matched and parallel to valve head. Quote Link to comment Share on other sites More sharing options...
John/Horace Posted March 8, 2020 Report Share Posted March 8, 2020 I believe there is a learn procedure run with a scanner after replacing cam sensor. There is a a way to do it your self without one, I’ve seen utube videos describing how, search. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
