Scott kelley Posted March 29, 2020 Report Share Posted March 29, 2020 2010 rt. 3.5. Last night one side blowing cold and one hot. Rear air is cold. At 3 pm today both front blowing hot and rear vents would not blow at all. At 9 pm tonight front vents blowing cold and rear vents cold. Not sure about all of this. What would keep them from working the same all the time ? Quote Link to comment Share on other sites More sharing options...
John/Horace Posted March 29, 2020 Report Share Posted March 29, 2020 Dozens of things. Temperature sensors, refrigerant levels etc. On heat settings it holds temp correctly, is a/c only thing erratic ? Not blowing at all means rear fan not coming on, no air flow.? Side to side is actuator in dash like mentioned in this forum several times. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted March 31, 2020 Official Dodge Support Report Share Posted March 31, 2020 On 3/28/2020 at 9:56 PM, Scott kelley said: 2010 rt. 3.5. Last night one side blowing cold and one hot. Rear air is cold. At 3 pm today both front blowing hot and rear vents would not blow at all. At 9 pm tonight front vents blowing cold and rear vents cold. Not sure about all of this. What would keep them from working the same all the time ? Hi @Scott kelley - We certainly understand why this would be concerning! If you're not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please know we would be more than happy to provide you with an additional layer of assistance for that process. Mark DodgeCares jkeaton 1 Quote Link to comment Share on other sites More sharing options...
